i2 / Charger 6.4L 2015 / Idle RPM
yousefmtw
Post by yousefmtw »
Greetings!
I have tried to modify the parameters to lower my idle RPM but was never successful.. gave it few shots! tried with both AC on and off options..
Other parameters that I messed with like throttle boost worked flawlessly previously..
What could be the cause??
Peace!
Re: i2 / Charger 6.4L 2015 / Idle RPM
yousefmtw
Post by yousefmtw »
mikel wrote:please post the info.xml file from the i2 drive.
File attached.
Thank you for your support.
yousefmtw
Post by yousefmtw »
I tried to set the Rev limiter on natural gear too and no matter how far I set it the RPM would still be limited to 4k after flashing ( or whatever the stock number is, I'm not able to check it at this moment).
I'm starting to think if I have any parameters working at all?
yousefmtw
Post by yousefmtw »
Any fixes for this?! :crashing:
yousefmtw
Post by yousefmtw »
It's 2016 already, if it isn't possible to do it just let me know it isn't.
I don't need to keep my car stock (been asked to return it to stock by the email support) for longer than that only to figure if I'm doing something wrong or that your device doesn't support this..
