Model U1746 workable with another vehicle after the first
RobertkSo2
Post by RobertkSo2 »
I would like to know if The Predator, model number U1746, is usable for another vehicle after I have used it with the first, please reply asap.
Thanks,
RE: Model U1746 workable with another vehicle after the firs
if your question is, can it be used to install a tune into another vehicle after you've installed a tune in the first vehicle, then no. You can only have a tune installed on one vehicle at a time. When you install the tune, the Predator locks itself to that vehicles VIN and can only be used on that vehicle.
but, you can remove the tune from vehicle 1 by restoring the original factory/oem backup, and then you'd be able to install a tune on vehicle 2 - provided the Predator model supports both vehicles.
you CAN use the Predator to read codes on other supported vehicles, even if the tune is installed on a different one.
Correct!
Return to “Predator Ford Gas”
