Help with throttle sticking 8.1?
srodholm
Post by srodholm »
Hi,
I have tried both the Diablo Tune and the 87 octane Tune both seem to cause the same issue. When I apply maybe 75% or more throttle in hangs or sticks. I have seen a few posts of people experiencing the same behavior and was hoping someone could help with which parameter needs to be adjusted to remedy this. It is really in usable the way it is.
Thanks,
Shane
2003 2500 HD 8.1
Re: Help with throttle sticking 8.1?
pleas eload the tune then post the backup and last tune written file from the tunes folder.
srodholm
Post by srodholm »
Here you go. Thanks
PCM_12577839_LastTuneWritten.grg
(30.37 KiB) Downloaded 143 times
PCM_12577839_Backup.grg
(30.35 KiB) Downloaded 130 times
thanks, the tuner is checking this out.
here you go, save this to the intune drive and load the custom tune to the truck.
PCM_12577839_custom.grg
(28.32 KiB) Downloaded 132 times
Badgasr
Post by Badgasr »
I'm currently having the same problem... what should I do?
post your file or email it to support please.
