Server Reported an error when selecting Calibration Updater
Posted: Sat Jan 19, 2008 10:18 am
by jferraino
Just got my tuner yesterday, and it required a calibration update. However when I select the Calibration Updater it will initialize and then an error is displayed " The server reported an error, Please contact Diablo Sport or try again later". There are no firewalls on this laptop or AV software, its running Windows XP. I have tried several times but the same message is given. Connections are fine.
my car info is below:
2007 Charger R/T
Purchased in West Palm Beach in 2/07
The calid displayed on the tuner is 05094804AJ
Car was recently updated over a week ago from the dealer.
Any help would be greatly appreciated from this ex-SuperChips user. thx
RE: Server Reported an error when selecting Calibration Upda
Posted: Sat Jan 19, 2008 11:08 am
by johnc
Windows XP SP2 does enable the built-in firewall by default without telling you. There are instructions on how to check this within the DS Downloader help file.
There is a chance that your calibration ID is brand new and not yet supported, but the message from the server would have additional information to indicate that.
There is a way for us to send you the update via email for a local install. Unfortunately, if this is the case, this is something that will have to be looked into on Monday.
Posted: Sat Jan 19, 2008 11:37 am
by jferraino
Johnc,
Thanks for the reply. I did double check XP's firewall setting for my connections and the firewall is turned off. If email is an option, no problem. Just kinda bummed out that it I won't be able to play around with the tuner this weekend. was looking forward to it
Posted: Mon Jan 21, 2008 9:58 am
by christina
That calibration is a new calid and was released after our last revision. There will be an update available very shortly to support it.
Posted: Mon Jan 21, 2008 11:07 am
by Tyrant
Christina, can we expect it some time this week... i was told last friday would be the day.. but i understand that you guys have many projects to work on and are very busy.. but at the same time its been almost 3 months and i still havent been able to use my predator!
Posted: Mon Jan 21, 2008 1:43 pm
Tyrant wrote:Christina, can we expect it some time this week... i was told last friday would be the day.. but i understand that you guys have many projects to work on and are very busy.. but at the same time its been almost 3 months and i still havent been able to use my predator!
They are busy working on this right now.
Posted: Mon Jan 21, 2008 6:05 pm
by jferraino
Christina,
thanks for the update today. I'll check back in a couple of days. thx
Posted: Fri Jan 25, 2008 12:20 am
by jferraino
Just checking in to see if there might be an update before the weekend is here. thx
Posted: Fri Jan 25, 2008 10:10 am
It is in testing now, should be released next week.
Posted: Fri Jan 25, 2008 10:31 am
by jferraino
Cool. Thanks Mike.
Posted: Mon Jan 28, 2008 10:05 pm
by jferraino
Thanks for posting r19, but..... i was trying to run the calibration updater and still received an error. This time it was different. It provided a code (3) asking to make sure I was connected to the internet. I had no problems hitting any websites or downoading the latest crom during this time. I called tech support and they instructed me to load r19 to the tuner first and then try again. The tune loaded no problem but I was still getting the error even after powering down and starting the unit. I decided to try and tune the car and I did not receive a message that I needed an update and it allowed me to tune for 93 CAI no problems. I guess my question is do I have the proper calibration file for r19 or am I good to go..thanks for your help.
Posted: Tue Jan 29, 2008 11:53 am
by jferraino
Just wanted to let eveyone know that I went ahead and restarted from scratch and I am no longer receiving the server error. All is good. thx
Posted: Tue Jan 29, 2008 12:17 pm
by johan
Good deal ,did you install the tunes yet?
Posted: Tue Jan 29, 2008 12:40 pm
by jferraino
Johan,
I went ahead and installed the 93 w/ CAI and so far so good. The only thing I can comment on is when I brake somewhat aggresivley and the car downshifts through all the gears i've noticed a shake that was not there before. I can go back and reset to stock to check but other than that I am happy that I'm finally using the product. thx
