Calibration Update Intune i1000 Issue
Posted: Sat Dec 12, 2015 10:29 pm
by DOHKORZA13
Hi Everyone.
I bought used intune i1000 for my neon srt4 2005.
First I plugged the intune in a friend car (to probe it) and it tunes with out problem(srt4 neon 2004) .
Then I go back with the intune un-married and plug in my car and it says that I need a calibration update so I execute intune.exe it finds the calibration update and the screen on intune.exe have the next message:
+ Calibration updates loaded to intune. please follow the instructions on the screen. this process may take several minutes. Please be patient.
+ Then I followed the instructions on intune display calibration update 05029415ah is already loaded then I press continue button.
+ I leave it 2 hours and then all the night and never install the calibration update.
Can anyone help me with this particular issue.
Forgive me for my bad English.
I attached you the xml File.
Best Regards.
Re: Calibration Update Intune i1000 Issue
Posted: Mon Dec 14, 2015 1:14 pm
go to the car and load the update to the pcm then you can load the tune.
Posted: Mon Dec 14, 2015 10:58 pm
by DOHKORZA13
Thanks my friend im in the car and idont see the option to writethe pcm is that menu on settings menu?
Posted: Tue Dec 15, 2015 1:23 pm
by DOHKORZA13
It doesn´t update the pcm with the option tune vehicle , it says connect to pc for calibration update, I think that the calibration update is in the intune but for some reason don´t want to write the pcm.
Posted: Tue Dec 15, 2015 1:32 pm
if the file downloaded to the tool, go to the vehicle and select tune vehicle/write vehicle and it will prompt you to load the update.
Posted: Wed Dec 16, 2015 12:45 am
by DOHKORZA13
it`s on the same situation the intune doesn't write the pcm and the calibration update is on the intune is what the intune.exe says, do I need to go with dodge and ask them for update the pcm before I can tune the car?, send u again the xml.
Thanks Mike.
Posted: Wed Dec 16, 2015 3:54 pm
by DOHKORZA13
Mike could u help me please?, the intune don´t want to write the pcm it says that need to download the calibration update and asks for plug it to the PC for search the calibration update , but the calibration update is in the intune.
Best regards.
Thanks for your support and attention.
Posted: Wed Dec 16, 2015 4:43 pm
go to settings/advanced/clear all updates to get rid of the current requests, then start over.
there are 2 requests currently, one from a different vehicle, which is likely confusing the situation.
Posted: Wed Dec 16, 2015 5:16 pm
by DOHKORZA13
Yes thanks my friend, i think the first request is not from my car, I gonna probe it in the night and I give you back a feedback
Posted: Thu Dec 17, 2015 12:07 am
by DOHKORZA13
It works beatifull, thanks a lot master mike!!!
Posted: Sun Feb 05, 2017 1:05 am
by outrid3r
Hi Mike
You were a great help when I first set up my tuner for my truck, THANK YOU! I am having another issue as I am selling my truck on monday. I seem to be having some issues with my calibration update when I try to restore my factory settings. When I plug my intune into my computer and it checks for update, the updater says no updates found. Great. Then when I plug it into my truck and press Restore Vehicle it says check PCM for calibration update, then it says no back ups found. I remember reading just a few moments ago about uninstalling the tuner before you bring it in to the shop when they check it for codes. I did not restore factory settings when I brought it in last month. Could the dealer have flashed over my calibration, rendering the tuner inept? Side note, when I access the tunes folder, it has 3 files: diablodcxtunes.tif, and then my VIN back up file and VIN lasttunewritten file. I believe my factory settings are saved in that folder, but the tuner and the truck aren't recognizing each other. I really need to reset my factory settings pronto, or I'll be selling my truck with MPG tune and leaving my tuner locked for when I buy my new vehicle. Any help would be greatly appreciated
THANKS!!
Posted: Mon Feb 06, 2017 10:36 am
outrid3r wrote:Hi Mike
THANKS!!
sure sounds like they updated the pcm, yes.
Posted: Mon Feb 06, 2017 5:21 pm
by outrid3r
Ok, can you help me reset my truck to its original settings? Thanks!
