Newbie question
Illss1
Newbie question
Post by Illss1 »
I see on this : Predator Updates Last Update Revision File
Release 18 (current)(Idle surge fix, Autostick fix for 06-07 5.7L,Autstick feature removed from 07 SRT8, Live data export fix, support for 06 jeep srt8(export),MBT spark adjustment added, knock sensor parameter removed) 11-19-07 r18 u7135-8r18 (crom) 864k
Release 17 Support for, early05,export and police calids added. Live Data added.) 10-30-07 r17
Test 16a(Fix for quick adjust issues in r16, except autostick disable in 07srt8) 10-17-07 t16a
Release 16 (EGR/MDS/Rear 02 disable,low throttle response improvement,wot fuel adjust fix) 10-17-07 r16
Release 14 (Release) 09-28-07 r14
MY PREDATOR SAYS : Predator v.8r14 ......... my car is an 06 CSRT8 an i'm going over threads trying to understand this stuff because these 16 an up doesnt fix anything on a 06 CSRT8 right ? Otherwise it would say correct ? SO DO I OR SHOULD I HAVE TO DOWNLOAD THIS 8R18 ?[/b]
Illss1
RE: Newbie question
Post by Illss1 »
Also one last question how do i UNALTER a can tune ? I altered a setting an i want to unalter it to a untouched can tune .
06 Charger SRT8 inferno red with predator (my tune) ,mopar cai ,180 stat........ 12.7 @ 110 and currently 81,000 miles
06 TBSS AWD all stock for now......
08 Jeep Wrangler 4DR redrock w/AEV 6.1 hemiswap and a long list of mods ........
Illss1
RE: Newbie question
Post by Illss1 »
RE: Newbie question
Go into Quick Adjust, then Restore Quick Adjust, the Restore Defaults. That will put it back to the original settings.
Illss1
Re: RE: Newbie question
Post by Illss1 »
Mike_Levy wrote:Go into Quick Adjust, then Restore Quick Adjust, the Restore Defaults. That will put it back to the original settings.
Thanks cool but what about the first question in post no.1?
RE: Re: RE: Newbie question
I would download the update. It improves the Data logging, which in my opinion is a very important feature. Thats actually the only reason I'm still using the later version. I liked 16a the best, but am dealing with 18 to keep the logging updates and other stuff.
You have 14, which is old and doesn't have the better features. Go to at least 16a, if you can find it, if not all the way to 18.
