torque manangment
gasjob2500hd
torque manangment
Post by gasjob2500hd »
Torque Management
PLEASE NOTE: Disabling torque management will put greater stress on your drive line.
* TM Abuse Mode time limit:
This is the time in abuse mode as a function of temperature. Turning it off in conjunction with Upshift Torque reduction and %Torque Reduction vs RPM will eliminate torque management.
* %Torque Reduction vs RPM:
Torque reduction as a function of RPM, turning it off in conjunction with TM abuse mode time limit and upshift torque reduction will eliminate torque management.
* Upshift Torque reduction:
Torque reduction control for each individual gear, turning it off in conjunction with TM abuse mode time limit and %Torque Reduction vs RPM will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
this is straight from the website i have all three off should i leave the upshift on
is this guna do damage if i leave it off?
RE: torque manangment
We recommend leaving the 3rd one on for better shifting performance in trucks.
