Knock sensor voltage PID and DataViewer
Posted: Fri Jan 15, 2016 10:20 am
by AlexIV
I can select knock sensor voltage at the Intune and record it. But I never saw the option to see that pid at DataV. Might be I just missed that ?
Its important for me as sometimes I saw voltage 4.99 V at idle at one or at two banks. Some times zero and zero with the same fuel and weather in tank. I can not understand why knocks are at idle. It should not be like so.
So wanted to see the logs after drive but I didn't found it via DV.
Thanks in advance
Re: Knock sensor voltage PID and DataViewer
Posted: Fri Jan 15, 2016 10:28 am
post the log...
Posted: Fri Jan 15, 2016 10:52 am
by AlexIV
mikel wrote:post the log...
here you are
Posted: Fri Jan 15, 2016 10:58 am
well, it is not in that log, try the restore default PID option in the logging menu and try it again.
Posted: Fri Jan 15, 2016 11:01 am
by AlexIV
mikel wrote:well, it is not in that log, try the restore default PID option in the logging menu and try it again.
Ok, I will post it later, thanks !
