I have been trying to log AFR/Lambda reported, but it never shows in the logs. Commanded shows up just fine though. Is this a limitation or am i doing something wrong? trying to log the following:
AFR/Lambda reported B1
throttle angle
rpm
LTFT B1 (always around -4)
LTFT B2 (always around -8)
cat temp
timing advance cyl 1
even if you can't help with the equivalence ratio logging, do my LTFT's mean my tune is off or i have a problem? was going to attempt to use dslog redux but can't get the needed parameters in log.
thanks for all you guys do!
AFR/Lambda reported not logging?
Re: AFR/Lambda reported not logging?
post the log...
if csv format isn't good i will grab my device at lunch and post the log
- WARM_IDLE_10MIN.csv
- (3.94 MiB) Downloaded 263 times
yeah, the actual log please.
here ya go
- WARMIDLE10.LOG
- (425.75 KiB) Downloaded 262 times
have you had a chance to look at the log mike?
DiabloMatt
i opened the log and bank 1 and 2 lambda are showing fine. what version of data viewer are you using?
or are you saying that you cannot see it on the tool?
- Capture.PNG (124.06 KiB) Viewed 4139 times
i cannot see it in data viewer, using version 3.3.0.8.......and i clicked on help and noticed the version build is march of 2011. sigh. went to your downloads and pulled down the newest version 3.3.0.17, now everything is showing. I am sorry for wasting your time and appreciate all your help at diablosport. i assumed when i installed the software from CD it would have checked for new versions because the trinity did. my bad. Thank you! i am going to verify DSdownloader is up to date now also
DiabloMatt
icepic wrote:i cannot see it in data viewer, using version 3.3.0.8.......and i clicked on help and noticed the version build is march of 2011. sigh. went to your downloads and pulled down the newest version 3.3.0.17, now everything is showing. I am sorry for wasting your time and appreciate all your help at diablosport. i assumed when i installed the software from CD it would have checked for new versions because the trinity did. my bad. Thank you! i am going to verify DSdownloader is up to date now also
no problem
ya the cd only gets you up and running you have to download the latest stuff. we are working on an auto updater though. let me know how it goes
