Making Trinity to read boost in psi
retromusclecar
How do I configure the trinity to read boost in psi?
Re: Making Trinity to read boost in psi
in logging menu click on the boost gauge and select change display units, then save the layout with a new name and it will show up in that layout as psi.
retromusclecar
Thanks got that done, but it's not reading anything do I need to add an external sensor? Vortech super charger.mikel wrote:in logging menu click on the boost gauge and select change display units, then save the layout with a new name and it will show up in that layout as psi.
no...did you save the layout?
retromusclecar
Layout? gauge layout right? Went out and did a new layout, Boost, AFR, MAP, Intake temp F, saved and put in monitoring and the boost still doesn't work.mikel wrote:no...did you save the layout?
retromusclecar
Guy's what else can you suggest, are there certain PID's that need to be with the boost to make it work, like a special layout?
there is a walk through in the manual, but you click on the gauge and select change display units, select pi, then when its done, click the red X in the corner and choose to save the layout with a new name.
retromusclecar
Ok setup a layout with Boost, OBDII MAP, OBDII Baro, engine RPM I got the boost to read for a split second, then nothing.
retromusclecar
Yes I did all thatmikel wrote:there is a walk through in the manual, but you click on the gauge and select change display units, select pi, then when its done, click the red X in the corner and choose to save the layout with a new name.
retromusclecar
Do you think an update is needed?retromusclecar wrote:Yes I did all thatmikel wrote:there is a walk through in the manual, but you click on the gauge and select change display units, select pi, then when its done, click the red X in the corner and choose to save the layout with a new name.
What version is on the tool currently?
This has worked for some time now....
retromusclecar
The trinity is not even a year old so It should be good, if you were to setup a page to read boost what pids would have to use with the boost pid in order for it to read?
