Registration Fix for Firmware 1r04i (possibly others)
brad2192
Post by brad2192 »
If anyone is having consistent registration errors when you're plugging in your InTune i1000 is suggest you open your "INTUNE" drive in my computer and view the info.xml by opening with a web browser (typically the default method). Check for a line that says "<registration status="0" sn="XXXXXXX-X"/>""
if it has the "0" in the "status" line, simply right click your info file and click "open with" and look for Wordpad under your options. At this point, you should be able to edit that "0" to a "1". Save that file by using buttons "Ctrl + S" or using the dropdown menu to save. Then go to your "Diablosport" drive and run the InTune application. Hope this helps!
