Cannot update until registered, but can't register
Hello,
I was updating my inTune today and something must have gone wrong because the GM tune database is missing. I tried to update manually, but it says "This intune cannot be updated until it is registered". I then tried installing the registration.itf file I found on the forums. The inTune reboots after I move the file, but it still isn't registered. Any ideas? Attached is my info.xml.
- info.xml
- (2.08 KiB) Downloaded 594 times
Re: Cannot update until registered, but can't register
save this to the intune drive.
- registration.itf
- (377 Bytes) Downloaded 579 times
Same problem with that file. I move it to the inTune drive and the inTune reboots, but it still says it's not registered.mikel wrote:save this to the intune drive.
I emailed you a file to use.Endo wrote:Same problem with that file. I move it to the inTune drive and the inTune reboots, but it still says it's not registered.mikel wrote:save this to the intune drive.
Thanks, Mike. It's working now.mikel wrote:I emailed you a file to use.Endo wrote:Same problem with that file. I move it to the inTune drive and the inTune reboots, but it still says it's not registered.mikel wrote:save this to the intune drive.
I am having this same issue.
chrisfischer7918
I'm having the same issue my email is [email protected]
- info.xml
- (1.68 KiB) Downloaded 554 times
My intune will not let me register either. I've tried many times, here is my info
- info.xml
- (2.35 KiB) Downloaded 504 times
I emailed both of you a registration file.
I have the same problem. Once it reboots it says it can't update until its registered.
custommasters
Hi . I have the same problem . I tried to update manually, but it says "This intune cannot be updated until it is registered". I then tried installing the registration.itf file I found on the forums. Now i have a new message "A calibration update has been detected for an unknown vehicle.Please contact Diablosport for further information" And i have enouther error "Tool oem is missing" Please help me.I don't know what to do.
- IMG_1700 (1).JPG (1.52 MiB) Viewed 11206 times
- info.xml
- (557 Bytes) Downloaded 436 times
yeah you can't use someone elses registration file man.. have to wait for one to be created for yours..
this one will work for anyone.
- _registration.itf
- (387 Bytes) Downloaded 507 times
custommasters
tool oem is missing. nothing is changed...... Last month i changed my PCM in jeep .Unplugged my diablo sport from my old pcm . And now i can not tune my new PCM in my car . But scan tool is aviable . Diablo writes my that my vin number needs a calibration and not supported. My car is jeep grand cherokee str8 2006 year 6.1 hemi
gsamford4818
I'm having the same issue as most people here. I can't get my I-1000 to update and I have tried using the registration file that has been used here many times. Every time it reboots it says it can't be updated until it is registered.
My email is [email protected]
- info.xml
- Here is my xml file
- (640 Bytes) Downloaded 460 times
