v8r20
Posted: Fri Feb 01, 2008 12:07 pm
by bob34787
loaded r20 into car last night went for ride this morning and the following things hsappened:
1. car went into limp mode, turnrd car off and reststarted and was fine for about 200 yards, than back to limp mode. This went on for about 5 miles until I got home.
2. ESP was disabled under quick adjust, however when driving the esp light and anti-lock brake light went out for about 1/4 mile than came back on.
3. CEL caqme on. No codes appeared in the tuner but clearing trouble codes option did turn off the light.
I called and talked to christy and was told that the esp disable function might have caused all of this, does that sound correct ? I did not have these problems with r18 or r19 but apparently cannot go back to them ? Itried but it says I need a calibration update but I get the same server error that I got two days ago when going to r19. Can I go back ?
07 charger 5.7
calid 05187835AB
RE: v8r20
Posted: Fri Feb 01, 2008 12:13 pm
Did you do a calibration update on r19 when you first loaded it?
If so, you can go back to r19 after restoring the original backup to the car, but r18 will not recognize the new calid.
RE: v8r20
Posted: Fri Feb 01, 2008 1:15 pm
by bob34787
yes I did, So I can go back to r19. I will try that
thanks
RE: v8r20
Posted: Fri Feb 01, 2008 10:21 pm
by kbyrd
okay, so i have a magnum 5.7. i ran the calibrator update to allow me to do so, what happens if i want to go back to a load pre-r19? When i try to flash back to r18 or before I get the calibration needed, but when I try to run the update from the DSdownloader it gives an error:
The server reported an error. Please contact DiabloSport or try again later..........
thanks.
RE: v8r20
Posted: Sat Feb 02, 2008 7:04 am
by bob34787
you cannot go back any further than r19 now. I wish I would have known that I would have stayed with 18
RE: v8r20
Posted: Sat Feb 02, 2008 2:01 pm
by kbyrd
man, i wish i would have known that as well. i am partial to the 16a load, but cant get back to it now....i put 19 on and it seems better to me than r20...
RE: v8r20
Posted: Sat Feb 02, 2008 9:53 pm
by bob34787
for some reason r20 gave my car all kinds of problems, I don't know, maybe it just had PMS that day. however r19 seems to be fine
RE: v8r20
Posted: Sat Feb 02, 2008 11:01 pm
by kbyrd
yeah..i put 20 on and kept getting BAS and Mr. Squiggles before even stepping on it. i restarted a few times and it continued to happen, so i put 19 on. 19 is okay, but nothing like 16a.
RE: v8r20
Posted: Sun Feb 03, 2008 6:34 am
by bob34787
yes 16a was also my favorite. I still have my original backup from before the update but do not know if I can reload it.
Posted: Sun Feb 03, 2008 7:08 pm
by jferraino
I'm new to this forum and I have seen many posts where people would like to have the throttle response of the 16a tune or be able to get back to it. I did not have an opportunity to use that version but based on the threads that are being thrown out there on various forums perhaps diablo sport could reconsider. I kinda bummed out that I did not have a chance to use it myself, but if it were available again I would certainly give it a spin.
Posted: Mon Feb 04, 2008 6:13 am
by bob34787
well if you have not updated your calid let me know, I have all the old versions and could send you r16 or r16a.
16a
Posted: Mon Feb 04, 2008 12:42 pm
by HemiNewbie
Count me in on the 16a tune. Sounds to me that I may be able to load it. "07 5.7 Magnum
Dale
RE: 16a
Posted: Tue Feb 05, 2008 5:29 pm
by UKCHRYSLER300
looks like whatever version you loaded AND had to update your calid you cannot go further back than that original version.I bought my pred in dec 07 and loaded v18,it updated calid and I cant load 17,16a16,14 etc.I loaded v20 when it came out,wasnt happy and reloaded v18 successfully
Posted: Tue Feb 05, 2008 6:51 pm
by jferraino
Bob ..thanks for offering the previous version(16a). sometime ago I went ahead and downloded previous versions before my tuner was shipped to me but I started with 19r because my car was recently flashed by the dearership when I had it in for service a couple of weeks ago. I was hoping to try some of the earlier versions based on several threads i've read. If sending it in was an option I would have done that.
