wide band air fuel
wide band air fuel
Is diablo going to build an A/F kit for the trinity since it is one of the gauge choices?? It would be nice not to have to get another gauge just for the sender. Or at least recommend an easier way.
DiabloMatt
Re: wide band air fuel
Cratos wrote:Is diablo going to build an A/F kit for the trinity since it is one of the gauge choices?? It would be nice not to have to get another gauge just for the sender. Or at least recommend an easier way.
not at this time. HOWEVER, you can use the new innovate lc-2 you can buy it for sub $200 and it does NOT have a gauge. it is only the controller and you can wire the analog output to the trinity and you are good to go
Sounds good. Now how can I get my Trinity to read in AFR numbers instead of 0 to 5 Volts? My Innovate LC-2 is up and running/logging but the 0-5V info isn't useable by Hemifever. They need AFR numbers to build a fuel map. Any help would be much appreciated.
2012 Ram Dually
2015 Ram Sport Quad Cab
those values are provided by the wideband manufacturer.
