I recently bought the Diablo I2 and got some custom tunes from BAMA and when I try to tune the car, it shows there's no custom tunes available when I have a 93 performance and a 93 race tune on the device itself. Is the folder incorrectly named or?
On the computer, it shows up as
i2(F:) > tunes > 93p.frg 93r.frg
Update:
I tried to put the tunes in the regular i2 folder and I end up getting an error.
Import Tune decode error: -1
I go to load them and the custom tune bar is dimmed out and I can't access them, is something named incorrectly?
XML doc is uploaded
Custom tunes not showing up?
Fifthstring
Re: Custom tunes not showing up?
I think we were emailing with you, I think you are all set now.
Let us know if you need anything else.
Fifthstring
Currently emailing now, not yet solved though. Hopefully soon.
I'm having the same problem. Custom tune is in "tunes" folder but custom tune section is greyed out on install screen
IVMOTORSPORTS.COM
custom tunes should not go in a folder, place them in the root of the i2 drive and the tool will import them from there
same here man i dont have them what should i domikel wrote:custom tunes should not go in a folder, place them in the root of the i2 drive and the tool will import them from there
