Not working
bojack201
Not working
Post by bojack201 »
I have plugged the tuner into my computer multiple times and ran the updater multiple times after the initial update and it is still showing the message "This Vehicle is currently not supported. An update may be required. Please plug the I2 into a PC to download any updates."
CaptainMike46
Re: Not working
Post by CaptainMike46 »
Same here....waiting on response from Technical Support.
Update on mine: I tried it again this afternoon after checking and verifying no updates were available.....everything worked perfectly and I tuned the vehicle no problem. No idea what I was doing the other times I tried and failed.....
Re: Not working
bojack201
Re: Not working
Post by bojack201 »
mikel wrote:please post the info.xml file from the i2 drive.
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="14U7Z5GYRW"/>
-<applications count="5">
<application rev="2r01f" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01c" name="gui"/>
<application rev="2r01b" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01c" vin="2r01fa" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" tune="2r01c" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
<last-connected vin="1C6RD7GT1CS270424" mfr="DCX" calid="68064920AE"/>
<licenses tuned="0" available="1"/>
<unsupported vin="1C6RD7GT1CS270424" calid="68064920AE" oem="DCX"/>
<reg reg="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"/>
</tool_info>
bojack201
Re: Not working
Post by bojack201 »
I also got in contact with customer support yesterday and he assured me that it was a server issue and would be fixed within a couple hours and I've tried it 3 times since no dice :(
Re: Not working
can you please attach the actual info.xml file?
72d100
Re: Not working
Post by 72d100 »
They told me it was a server issue as well. I'm gonna try again after work
Re: Not working
if you will attach the file I am requesting I may be able to make the file for you and circumvent the server.
Thakns
bojack201
Re: Not working
Post by bojack201 »
mikel wrote:if you will attach the file I am requesting I may be able to make the file for you and circumvent the server.
Thakns
I do apologize, how do I attach the file?
bojack201
Re: Not working
Post by bojack201 »
Thakns
figured it out
kburntrt
Re: Not working
Post by kburntrt »
Piggybacking on this thread, i'm having the same problem for my '14 Charger. Attached is my xml file from the i2.
Re: Not working
Thakns
figured it out
here is your file
Re: Not working
kburntrt wrote:Piggybacking on this thread, i'm having the same problem for my '14 Charger. Attached is my xml file from the i2.
here is your file
kburntrt
Re: Not working
Post by kburntrt »
Thank you! Sorry to have to ask, does it matter if i'm running on a Mac? Also where should I place the new file?
Re: Not working
root of the i2 drive, then you will need to eject the drive on a mac to allow the file to import.
