U7193, Procharger
Posted: Fri Mar 16, 2007 10:50 pm
by UsualRob
I have an 04 GTO 6 speed and am about to install a procharger. I already have the programmer so i didn't get it with the kit. The blower will be running 8 P.S.I of boost, and just incase you need the info, using 60 lbs. injectors. The programmer I have is the U7193. I just need a tune that will get me on the highway and to a dyno shop. There are no other mods to the car, other than the blower that is about to go in. Thank you in advance.
RE: U7193, Procharger
Posted: Sat Mar 17, 2007 9:30 am
by johan
You can send me your backup and i can get you going. I also need to know what brand the injectors are.
Posted: Sat Mar 17, 2007 7:28 pm
by UsualRob
thanks johan
What do you mean by backup? The injectors I am using are Siemans 60 lbs. high impedance(pencil type), with a gss340 walbro pump.
Posted: Sun Mar 18, 2007 8:00 pm
by johan
You will need to download the 03-04 GM pc interface and transfer your vehicles original backup from the predator to your pc so you can then e-mail it to me. Youre in luck too as I just dyno tuned an 04 GTO procharged with 8pci and those same injectors this weekend, so you will get a spot on tune for it.
Posted: Wed Mar 21, 2007 8:51 pm
by UsualRob
Hey Johan, i just sent you an email with my backup in it. I hope. What kind of HP should I hope to get when its all said and done. thank you
Posted: Thu Mar 22, 2007 11:44 am
by johan
Toon is in the mail, the vehicle i did was an auto and made 450hp and 400ft/lbs on 8psi. You should make more since yours is a 6spd.
Posted: Thu Mar 22, 2007 12:15 pm
The A4 car also had a loose converter in it, which never equates to big dyno #s.
