'13 Charger R/T not supported
beam3215
Post by beam3215 »
Plugged in tool for updates, launching Updater, and got "no updates found" response. Plugged in i2 to car, and got "vehicle not supported." Got caught up in the vicious cycle.....I called Tech Support and sent my info file via e-mail to Daniel....no response. Here is my info file. Would very much like to solve this ASAP. We should be able use these w/ no problems right out of the box. Too many problems popping up w/ the i2.
'13 R/T Charger w/ STP: DS catch can / Mopar CAI / SRT headers & mid pipes
Re: '13 Charger R/T not supported
I dont see any issue here, the updater is pulling the file down for your car, did you connect it to a pc and run the updater yet?
It will download the file to your tool then let you load it to the cart, then you can tune it.
beam3215
Post by beam3215 »
Yes, I did. I will try it again. Thanks for the reply, Mike.
beam3215
Post by beam3215 »
Good news, the updater did work. I had opened it several times before, but it did not connect. The car runs awesome, now. A much better / faster throttle response, as well as much improved shifting. The only bug is when attempting to modify traction control. It says "failed" when applying the change....any ideas?
Andy
beam3215
Post by beam3215 »
Un.able to modify in the tune and or quick adjust
beam3215
Post by beam3215 »
...anyone???
