Vin not found/no start
Posted: Sat Feb 20, 2016 6:20 pm
by The_detailer
2003 Silverado. Had a CEL come on. Checked and cleared the codes with the programmer. I figured while I'm here let's change up the tune. Haven't done it in lord knows how long. Well 17% into loading the time I get script error. So I reset, hook up battery tender in case it was low voltage. Start the process over. Now I get "VIN not found" after unplugging everything the truck does not start. PLEASE HELP!!!
Re: Vin not found/no start
Posted: Sat Feb 20, 2016 6:23 pm
by The_detailer
Side note the CEL was for mass air flow sensor.
Posted: Tue Feb 23, 2016 1:14 pm
sounds like a really old tool, this may be a touch spot ass these really old tools dont have the recovery options of the newer ones.
If the tool will not restore the tune we'll need to get it flashed by a dealer or pull the pcm and send it here and we can flash it for you.
Posted: Tue Sep 26, 2017 10:49 am
by Jamestorug
as these trucks get older, it is possible for a simple sensor failure or harness issue to cause a problem... were there any codes when it would not start?
