predator/puck stack (UD7133)...
PowerPuck/Extreme PowerPuck Support
fyrguy316
Post by fyrguy316 »
i'm new to these programmers so bear with me. i just recieved my predator and puck friday (march 16). my original plan was to get just the puck and run the 60 HP setting, but everyone said the stack was the way to go. heres my question: i tow a 25 ft gooesneck. load and trailer weight is around 12,500. which combination would be more logical to use? the puck alone, the predator alone or the combination of the two? most people on here that i've read are running auto trannys. i have the 6 spd which will handle far more than the autos, but my clutch is the weak link here. any input would appreciated. thanks.
truck specs:
05' cummins quad cab, 6 spd, afe stage 2 intake, MBRP 4 in. exhaust, EGT and boost gauges.
johan
RE: predator/puck stack (UD7133)...
Post by johan »
I would install the tow stack tune with the Puck and while towing set the puck to the low hp setting and ensure to monitor your egt's, they should be fine but make it a habit to always keep an eye on the under load conditions. When your not towing set the puck to the higher settings and enjoy.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
fyrguy316
Post by fyrguy316 »
so if i have the stack tow tune downloaded into the truck and the puck on 60 HP, how much HP am adding?
Return to “PowerPuck/Extreme PowerPuck”
