CUSTOM TUNE REQUESTED
CJs197
Post by CJs197 »
I'd like to request a Custom 91 octane performance tune.
I have a 2005 Ford Mustang GT manual trans.
Details of my tuner device are in my signature.
The specific item I would like to have customized is my Dashpot setting. Reason is because my idle takes too long to drop between shifts.
I've already checked for vacuum leaks and cleaned the throttle body with no change to the slow rpm drop. It takes about 4-5 seconds for idle to drop from 3500 rpm to idle.
I recorded the slow dropping RPM's, click the image below to see it.
2005 Mustang GT
FR Axle Back Stingers
Predator u7140 v9r.09
Re: CUSTOM TUNE REQUESTED
no CAI on the car?
post the current last tune written file please.
CJs197
Post by CJs197 »
No cai installed, do I have to upload the actual tune I'm using or can I tell you which one I'm using?
If I can just say which one it is, it's the 91 octane Performance Tune for a Manual trans 05 GT. My predator model and version are listed in my signature.
2005 Mustang GT
CJs197
Post by CJs197 »
no Cold Air Intake.
FBJR3G5_custom.frg
(4.25 KiB) Downloaded 485 times
2005 Mustang GT
CJs197 wrote:no Cold Air Intake.
give this a shot
FBJR3G5_dashopt.frg
(960.14 KiB) Downloaded 533 times
CJs197
Post by CJs197 »
Thanks Mikel! I'll try it out tonite.
Could you tell me what setting the dashpot was set to and what it is set to now?
2005 Mustang GT
CJs197
Post by CJs197 »
Well at a stand still, the RPMs come down quicker than before the custom tune but at speed, they come down slowly at the same rate as before and seem to drop as the vehicle speed drops. Any ideas why that would occur?
2005 Mustang GT
CJs197
Post by CJs197 »
Is there a setting called "drift" that is adjustable? I read on Mustang forum that a member who had the exact same issue that I'm having, went to a Ford Tech and they a vaguely recall the Tech altered something called drift which cured the issue.
2005 Mustang GT
DiabloMatt
Post by DiabloMatt »
here you go. try that. let me know if this is good or if you need more aggressive or less.
FBJR3G5_dashopt2.frg
(960.14 KiB) Downloaded 676 times
CJs197
Post by CJs197 »
DiabloMatt wrote:here you go. try that. let me know if this is good or if you need more aggressive or less.
Thanks Matt, I just confirmed that ill be picking up a JLT series 3 110mm CAI tonite, could you apply the Dashpot settings and settings for the JLT CAI into one tune?
2005 Mustang GT
DiabloMatt
here you go... :)
FBJR3G5_dashopt2JLT.frg
(960.14 KiB) Downloaded 551 times
CJs197
Post by CJs197 »
You guys are AWESOME!
2005 Mustang GT
CJs197
Post by CJs197 »
DiabloMatt wrote:here you go... :)
Installed the JLT series 3 cai and tune, it's awesome but I need the idle to drop faster still. It's alittle better but it's still slow to drop.
2005 Mustang GT
Can you record a quick log with the default pids so Matt can check it out?
DiabloMatt
FBJR3G5_dashopt3JLT.frg
(960.14 KiB) Downloaded 515 times
Return to “Predator Ford Gas”
