Dealer Flash LB7 Forgot to Back Out
Posted: Thu Feb 07, 2008 12:14 pm
by KSzabo
My 4WD went out on my '03 Silverado 3500 dealer said they had to flash the programming to recover 4WD. They did so, however I had not backed out my Predator U7180 programming. Will I have to send the unit back to get it reauthorized? If so, the dealer I bought it from back in 2003, is no longer in your authorized dealer lists. I origiinally purchased it from Granatelli Motor Sports, and on their web site they no longer carry Predators.
RE: Dealer Flash LB7 Forgot to Back Out
Posted: Thu Feb 07, 2008 12:35 pm
Fill out an RMA request and send the tool in with a copy of the original proof of purchase receipt.
Posted: Thu Feb 07, 2008 12:44 pm
by KSzabo
I was going to do that, but it appears Granatelli Motor Sports is no longer one of your dealers and does not appear in your list.
Posted: Thu Feb 07, 2008 12:50 pm
As long as you have the receipt, you're fine.
Posted: Thu Feb 07, 2008 7:43 pm
by KSzabo
Looks like I won't need to send it back after all. I tried it in my '03 Duramax when I got it home from the dealer service. I chose Install Performance option and it backed up and installed fine. Either this Ganatelli version does not need to be unlocked or I forgot to Install performance after the last time I took it to the Dealer. By the way I found my original receipt and although it is a Granatelli Predator and I bought it from Stylin Concepts which also is not on your Distributor List.
Posted: Fri Feb 08, 2008 10:30 am
Sounds like they did not reflash it after all....
