2013 Wrangler 3.6L P0128 code
dwasill
Post by dwasill »
I'm running a 180 degree thermostat in conjunction with the DCX fan speed settings and my ECU keeps throwing a P0128 code. Can I get a tune update to lower the expected baseline engine temp or can you publish a DCX update that accommodates lower thermostats in conjunction with your fans speed settings?
Re: 2013 Wrangler 3.6L P0128 code
dwasill wrote:I'm running a 180 degree thermostat in conjunction with the DCX fan speed settings and my ECU keeps throwing a P0128 code. Can I get a tune update to lower the expected baseline engine temp or can you publish a DCX update that accommodates lower thermostats in conjunction with your fans speed settings?
fix attached.
