I plugged in my in tune i1000 and let the program run its course then I tried to tune the truck and got a "vin needs an update" message and then when I hooked it back up to my pic I got this mess(image attached)
Please let me know what to do next.
2016 F150 2.7 EB Cal ID help
- image.png (1.1 MiB) Viewed 2148 times
Re: 2016 F150 2.7 EB Cal ID help
For whatever reason this file is not on the ford site. Could you possibly pop the little black cover off the top of the pcm case in the engine bay? It's on the passenger side firewall right at the top. The plastic cover is super easy and the label will be right below it. If you could post a pic of the label that would be really helpful an dI'll add it right away. No idea why it's not on the site.
Insert Clever comment here...
SohFast,
Is this what you need?
- image.png (1010.24 KiB) Viewed 2083 times
Heres my info file from the intune as well
- info.xml
- (6.74 KiB) Downloaded 153 times
I think we've already helped you as I recognize your calid, in case we haven't here is the update.
Also FYI: This is an i2 ITF as you posted an info file from and i2.
- FORD_TUNES-2t02hk.ITF
- (16.48 MiB) Downloaded 169 times
