Instructions on which programs exclude others?
flyntgr
Post by flyntgr »
If I use the quick setup, can I use the 91 or 93 octane setting, too? I
If I want to change the temps for the fans, etc, can I do this while in the quick setup mode, or are the two mutually exclusive of one another?
If I have installed the quick setup, does this mean I can't change from 91 octane to 93 octane without losing the shift firmness, autoshift disable, etc?
Sorry to ask such dumb questions, but the manual never mentions these issues. thanks, everyone! :?:
RE: Instructions on which programs exclude others?
I'll assume we are talking about a U7135 here, for a HEMI?
QA changes are seperate.
You can switch tunes while keeping the QA settings intact.
stang005
Post by stang005 »
I have the Mustang 2005 and have the same question, I installed the 93 octane setup, if i want to install firm shifting am i gonna lose the 93 octane setup? another question, what is the meaning of QA?
QA = Quick Adjust
stang005
Post by stang005 »
Ok, so does that mean that I can have both tunes at once? (93 octane and firm shifting)
concoursd
Post by concoursd »
there is no QA ability for Ford vehicles. The quick adjust feature is strictly a hemi predator feature.
If the predator does not list a 93 ocatane firm shift program then there isnt one. It may only offer you a 91 octane firm shift program. In that case then you would add a few degrees of timing to the 91 octane firm shift program when running 93 octane fuel.
stang005
Post by stang005 »
Well, the firm shifting was an example, my question is, for instance i have installed the 93 octane performance tune and then i want to reduce the idle in an x %, or set the cooling fan, will these setups being added to the 93 octane setup, or i will lose the 93 occtane and only will have i.e. the idle or the cooling fan setup?
You have to choose the tune you wish to mnodify before you make any changes.
stang005
Post by stang005 »
Ok, then in summary as i have the 93 octane setup installed, i have to choose "modify tune", then choose 93 octane and then select the set up i want to modify in the 93 tune (i.e. idle %) and at the end of the day i will have installed the 93 octane tune modified just in the idle.
Return to “General Questions”
