INTUNE i-1000 Changed gear ratios
Posted: Sun Apr 03, 2016 7:54 pm
by Zlester1313
I went from a 3.23 gear ratio to a 4.10 because of a bent axle. This as drastically changed my speedometer what do i do?
PCM_12604546_LastTuneWritten.grg
Re: INTUNE i-1000 Changed gear ratios
Posted: Mon Apr 11, 2016 11:41 pm
by brad2192
took me a while to get a response for this issue. The mods here are going to tell you that you need to purchase a custom tune because the I-1000 does not have the gear ratios in adjustable parameters for absolutely no good reason. I suggest using the "Diablo Tune" on the tuner and adjust max revs all the way to 7,200, the "Diablo Tune" unlocks your speed limiter. I do suggest at some point getting an aluminum driveshaft if you have not already. Shits gonna get loud and might be a little shaky!
Posted: Tue Apr 12, 2016 11:01 am
Zlester1313 wrote:I went from a 3.23 gear ratio to a 4.10 because of a bent axle. This as drastically changed my speedometer what do i do?
what vehicle is this?
Please post the backup file from the tunes folder as well.
