DIfficulty data logging
Lubricant
Post by Lubricant »
I have an Intune I-1000 for my 2005 Chrysler 300C 5.7
The issue I'm having is it's not logging the PIDS I want and I don't know how to select them.
When I go to datalog, it shows "ECU Data" and nothing else. It does save a log, and the log has information in it, but none of which my tuner needs.
RPM
PRATIO
LT fuel adaptives 1/1 and 2/1
ST knock retard
Those are all the things my tuner requested I log and none of those are in my logs. How can I make sure my intune records that data? Another thing to note is if I try 2 actions which require finding the ECU, it fails the second time, not sure if related (IE: I do one action that requires verification of vehicle info, works fine, then try another and it will not find my ecu) Not sure if related, but noteworthy I'm sure.
Attatched is what my InTune shows when I start recording.
Thanks in advance, help is always appreciated because this is my Daily driver and the tune is frighteningly bad... it's a start tune so it's to be expected I'm sure :)
Lubricant
Re: DIfficulty data logging
Post by Lubricant »
Good lord...
So, I figured data logging with the tuner itself is a no-go. So I tried datalogging via PC. GUESS WHAT! To no surprise, it doesn't work. It connects and enters Remote control mode, and tries to acquire vehicle info and won't find my ECU. I have tried disconnecting / reconnecting etc. Nothing worked. The tool & the PC have the latest firmware/software respectively.
What's wrong and how can I fix it?
