i2 sho tauras 2015
toolman7963
i2 sho tauras 2015
I bought a tuner and it does not go past needs an update to backup I have done this four times with no sucess how do I install this tune in my 2015 ford sho
Re: i2 sho tauras 2015
toolman7963
how do i do this?found it. <tool_info>
<registration sn='14U7Z5MZAB' status='0' tool_oem='DIABLO_F' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r01h'/>
<application name='updater' rev='missing'/>
<application name='gui' rev='2r01e'/>
<application name='installer' rev='2r01c'/>
<application name='logger' rev='2r01a'/>
</applications>
<databases dbnames='2r00' dtc='2r01a' vin='2r01g' gui='2r01c'>
<database mfr='DCX' pid='2r01cc'/>
<database mfr='FORD' tune='2r02g' pid='2r01cf'/>
<database mfr='GM' pid='2r01ba'/>
</databases>
<last-connected vin='1FAHP2KT6FG196078' mfr='FORD' calid='KHDP1DA'/>
<licenses available='1' tuned='0'/>
<unreadable calid='KHDP1DA' vin='1FAHP2KT6FG196078' oem='FORD'/>
<reg reg='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'/>
</tool_info>
</applications>
</databases>
</tool_info>
toolman7963
still no reply waiting
sorry, can you attach the file here please?
toolman7963
</applications>
</databases>
</tool_info>
It says no new updates when hooked on computer alone. It is when it is hooked up to the car I can,t get any farther which instructions say that on a eco boost it will ask for one but does it over and over
</applications>
</databases>
</tool_info>
toolman7963
by what I read the tuner can not find the calibration it may not be in the info bank look above for your files
please use the attach opton to attach the info file here or send it to us in and email with details to support @ diablosport.com
toolman7963
it has updated all it will on computer but when hooked to car it ask for update like it should for eco boost to. but keeps going to that screen again. the info files says it does not know my calibration please help
I'm pretty sure you've been helped already but here you go drop that on the i2 drive an let it load it. Then all will work.
https://www.dropbox.com/s/iu2rq7rfqsd0k ... l.ITF?dl=0
Insert Clever comment here...
toolman7963
I have been helped it works great but when I remove the speed limiter it loses all throtle body response and goes to idle speed only. Can this be fixed?
DiabloMatt
toolman7963 wrote:I have been helped it works great but when I remove the speed limiter it loses all throtle body response and goes to idle speed only. Can this be fixed?
its a glitch we are working on. if you use the "advance tune menu" instead of the easy tune menu, you can diable the speed limiter there and it will work just fine
