Page 1 of 2
InTune i-1000 freezes when connecting to 2010 Silverado
Posted: Mon Apr 18, 2016 4:54 pm
by carltonmj
When I try to connect my inTune to my 2010 Chevy Silverado, the inTune will recognize that it is connected to a vehicle, but when I click on either Tune Vehicle or Scan tool about 30 seconds in the spinning wheel will stop and the inTune will freeze. I have left it plugged in for about 25 min and nothing happens. Is there any insight on how to fix this?
Re: InTune i-1000 freezes when connecting to 2010 Silverado
Posted: Mon Apr 18, 2016 5:35 pm
please post the files from the tunes folder then we can reset it and get you going.
by 07Aspen
Im having the exact same problem bro. When i go to load a tune, the spinning wheel freezes. It seems that a lot of people are having this problem so hopefully they will soon have a solution.
IK this isnt my thread but i need help so here are the contents of my tune folder and my info.xml.
Also when i go to update my intune, this happens (picture attached)
Posted: Mon Apr 18, 2016 8:09 pm
by carltonmj
Thank you for the help Attached are all the files in the inTune folder. All the folders are empty except the info
Posted: Mon Apr 25, 2016 1:51 pm
by 07Aspen
BUMP...
Posted: Mon Apr 25, 2016 3:33 pm
07Aspen wrote:Im having the exact same problem bro. When i go to load a tune, the spinning wheel freezes. It seems that a lot of people are having this problem so hopefully they will soon have a solution.
we can reset the tool for you, for best results please email
[email protected] with the key shown under settings/advanced/registry reset, and include a link to this thread so we can get you going from there.
Posted: Mon Apr 25, 2016 3:34 pm
carltonmj wrote:Thank you for the help Attached are all the files in the inTune folder. All the folders are empty except the info
did you by chance ever delete the files?
The tool is married so they should be there....were you looking on a PC?
Posted: Tue Apr 26, 2016 1:05 pm
by carltonmj
mikel wrote:carltonmj wrote:Thank you for the help Attached are all the files in the inTune folder. All the folders are empty except the info
I may have deleted them when I tried to update the device. I am looking in the 3 folders that I can access. Yes I am on a PC
Posted: Mon May 02, 2016 9:55 am
by carltonmj
BUMP.....
Posted: Fri May 06, 2016 1:10 pm
by Z51vett
I've been having the exact same problem with my 2013 Sierra 5.3 for months. The tune is locked in to the truck and it just freezes when I try to plug in. I had Diablosport send me an updated file several months back and it did nothing. same problem. The tuner works fine plugging into my C6Z06 (can read codes but can't tune since tuner still locked to Sierra). I also have an OBDii dongle plug in for my cellphone that plugs in fine to the Sierra and reads all codes so it appears as if the OBDii port on the truck is fine since it connects to other devices and that the I-100 port is fine since it connects to my C6Z06 OBDii port. Perplexing but appears to be problem not with power but interfacing with the CAN.
Help needed! I really want to get the tune pulled from this truck so I can tune my C6Z06 now that spring is here.
Posted: Fri May 06, 2016 1:17 pm
by Z51vett
If Diablosport can help with pulling my original backup tune from my malfunctioning I-1000 for exporting onto a new I-2030 with multiple licenses (with a price break on a 2nd license) so I can return my Sierra back to its original tune (it needs service and emissions soon) I might just send back the I-1000 and purchase a new I-2030 so I can tune both vehicles with the same tuner in the future and be done!
Posted: Fri Jun 10, 2016 3:43 pm
by 07Aspen
Bump...
I'm still having the same problem even after a reset. I go to tune and it freezes on the spinning wheel, and for some reason after the reset i now have the intune 2 updater even though i have the intune 1000.
Posted: Mon Jun 13, 2016 11:42 am
by 07Aspen
bumpp
Posted: Mon Jun 13, 2016 5:22 pm
please post the current info file.
Posted: Tue Jun 14, 2016 1:42 pm
by 07Aspen
Ok here it is
