- I use a custom tune, but for some reason i am not able to modify any parameters, when i select any parameter menu item the device just stops and i have to unplug/plug
Eventually i could modify the throttle response but when i click apply it just instantly gives message that tune applied with no writing or compiling or anything
I am not able to register my device, i did twice through last couple of weeks but i didn't receive any mail or confirmation
When i connect the device to my PC it says that there is a problem with the device and wants to scan and fix
Some issues
Some issues
I have some issues i need help with:
Re: Some issues
the scan and fix is simply windows not knowing what it is, ignore that.
on the params, can you post the info.xml file from the i2 drive so we can check it out?
