2013 F-150 5.0- retune needed?
I recently purchased a used F150 that was tuned for 87 and 35" tires. I noticed the speedo is a bit off and since purchase I've added a K&N air filter and catback exhaust. Should I retune? and if so any recommendations?
Re: 2013 F-150 5.0- retune needed?
do you have the tool that was used to tune it initially?
yes the previous owner gave me the intune unit he used to tune the truckmikel wrote:do you have the tool that was used to tune it initially?
if you need to recal the speedo you can adjust it with the tuner no problem.
Is there a need and/or is it possible to tune due to the high flow air filter and the catback exhaust?mikel wrote:if you need to recal the speedo you can adjust it with the tuner no problem.
