Problem updating inTune\PCM Calibration message
Posted: Fri May 20, 2016 12:20 pm
by joedeal
Hi, When I tried to write a tune for the first time I got a message that the PCM may need calibration. So I tapped yes and took the inTune to my PC and tried to update. Every time I run the program it tries to download "cdrom-1r01w.itf", and say it cannot get the file from the web. I click OK then it tries to download other files I guess and gives "an error has occured" message and asks to disconnect and try again. I tried this a few times. The last time it gave the cdrom error but then it said "device up to date". Does that mean I should be good to go now? I have not tried writing the tune again yet since I am at work. I sent my xml by email last night (attached here as well). Vehicle is a 2011 Charger R/T.
Also when I try to register the device I get a "Page not found" error.
Thanks.
Re: Problem updating inTune\PCM Calibration message
Posted: Fri May 20, 2016 1:08 pm
this is being addressed and should be fixed before the end of the day.
Posted: Fri May 20, 2016 8:49 pm
by joedeal
Hi, sweet, I was able to get past the cdrom download part and update the device! but I am still stuck in an endless loop with the PCM calibration message.
I keep getting the prompt to disconnect and connect to a PC to check for the calibration. I do that and it says no updates on the device but when I try to write a tune it gives the same calibration message. if I tap no to the message it says "vehicle unsupported". Attached is the most recent info.xml.
HELP!
Posted: Mon May 23, 2016 9:55 am
this is not an i-1000-dcx, it will not work on the 2011 model.
Posted: Mon May 23, 2016 10:21 am
by joedeal
...it isnt? then what model is it? I purchased from ebay. It was listed as an i-1000dcx... :x
Posted: Mon May 23, 2016 10:42 am
this is a standard I-1000
what color is the box it came in?
<oem tool_oem="DIABLO"/>
Posted: Mon May 23, 2016 10:44 am
by joedeal
Crap. Listing definitely said DCX... It did not come with a box. So this tool works up to 2010?
Posted: Tue Jul 12, 2016 6:45 pm
by trax95008
open a case with paypal. you will get your money back
Posted: Tue Jul 19, 2016 10:02 am
joedeal wrote:Crap. Listing definitely said DCX... It did not come with a box. So this tool works up to 2010?
all gm/ford, and 03-10 Chrysler/dodge.
