1999 Ford F-350 V10 not supported
Posted: Sat Jun 04, 2016 10:24 am
by kogelch
I updated my intune last night, connected it to my 1999 ford f-350 v10. The intune asked me for the vin. After entering the vin I got a message stating my vehicle is not supported. I disconnected it and tried to update again, but it still says vehicle not supported. I also tried to drag and drop the ford tune download file into my intune but it says there isn't enough room. What file do I need to tune my truck. Please help.
Re: 1999 Ford F-350 V10 not supported
Posted: Sat Jun 04, 2016 10:45 pm
by kogelch
Can anyone please offer some insight as to how I can tune my truck. I'm not sure if I am supposed to use the ford download or the update, or both.
Posted: Mon Jun 06, 2016 11:03 pm
by kogelch
I've finally got the immune updated and communicating with my truck. But now the issue is unless I load just a plain tune my truck doesn't run. Last night I loaded the 93 octane tune and adjusted a few perimeters. This morning when I tried to start it. The truck wouldn't fire. I loaded the original tune back and it fired right up. So I loaded the upgraded 87 tune without adjusting anything and it again fired right up. I went back in to adjust shift pressures and after loading the changes it wouldn't start. So I changed the perimeters back to stock but it still wouldn't run. I loaded the original followed by loading the 87 tune and it started right up. I loaded the 91 tune and it started right up. But if I try to modify it at all it won't run.
Anyone ever seen this before.
Posted: Wed Jun 08, 2016 9:08 am
that is really odd, are there any codes present when it will not start?
Posted: Fri Jun 10, 2016 7:30 pm
by kogelch
not currently. Its not setting any codes.
Posted: Mon Jun 27, 2016 2:20 pm
by kogelch
Ok, so I've had some time to play around and go back and fourth with what works and what doesn't. So far the best I can tell is if I edit more than a couple parameters and load the tune to the truck it won't run. I'm able to add 2 degrees timing via global adder. If I add timing via rpm based it won't start after loading. If I try to mod the shift point rpm at all it won't start. I am able to mod partial throttle pressure for 1-2 and 2-3 and it will run. If I try to include 3-4 it won't start. I am not able to edit idle rpm, MAF, injector at all. All of these result in a no start. I've also found that when my intune is building a tune or loading a tune, the fuel pump in tank runs the whole time. Also there have been times that I load a tune and after my truck feels like it on steroids. Then other times it is under powered and can't get out of its own way. Please help. I really don't feel loved me sending it back if I don't have to. Is it possible for me to just send you some logs and build me a tune that I can load to my intune and then to the truck. Or what's the next step to get my device working please. :crashing:
Posted: Fri Jul 01, 2016 10:58 am
by kogelch
Any thought??
Posted: Fri Jul 01, 2016 3:05 pm
can you load a tune that casues the issues then post the backup and last tune written files here so we can check them out please?
Posted: Tue Aug 02, 2016 11:04 am
by kogelch
I decided to take it off and stop dealing with the hassle. I bought a livewire from 5star instead. I just don't know what to do with the Diablo from here. I have a Chrysler 300 SRT8 I was thinking about using it on. But I don't want it to cause problems. I think i just need to send it in to be repaired like you suggested a while back.
Posted: Tue Aug 02, 2016 11:26 am
what year is the 300?
