intune pcm calibration update
Posted: Wed Jun 08, 2016 4:46 pm
by bmh333
took my 2014 challenger rt to the dealership to have a speed sensor replaced and they flashed the pcm with a tune present. now every time i plug in it tells me i need a pcm calibration update and every update i have tried doesnt solve the problem. please help
Re: intune pcm calibration update
Posted: Thu Jun 09, 2016 11:55 am
did you restore the stock tune before going ot the dealer?
Post a copy of the current info.xml file here and we'll check it out.
Posted: Fri Jun 10, 2016 3:42 pm
by bmh333
no I didn't, I just did the reset registry and tried to retune the car but it still says the same thing.
Daniel has been helping me.
Posted: Tue Jan 03, 2017 7:11 pm
by Entrusted
I cannot get this to download on my I-1000, it says it needs a pcm update but I get nothing to put it on the unit when I click from the downloads page. I have a 2006 Daytona Charger that recently underwent a PC repair due to an error on the ASP Switch that shorted out because of magnetic waves supposedly from the Alternator. Strangely enough it fried the pc's ability to turn on the heated O2 sensors. After much much much money later the pc is now fixed and of course returned to super stock abilities. I need to update the pcm and I cannot do that because the tuner will not allow me to put it into that section that allows the pcm update. I need to see if the pc will take the same tuner that I have used for it due to the pc fix. I cannot see if it needs to be remarried though due to the pcm needing an update that I cannot put on the user tuner itself to update. Either I just don't remember how to use the files or put them on the tuner but I do know that I need help. If someone from diablo can help me by a pm I greatly appreciate it. I spent about an hour this am trying to contact someone via phone but I just got the wonderful music and message about the tuners that wasn't helpful at all. I greatly appreciate your time. -Dustin.
Posted: Wed Jan 04, 2017 9:15 am
Entrusted wrote:I cannot get this to download on my I-1000, it says it needs a pcm update but I get nothing to put it on the unit when I click from the downloads page. I have a 2006 Daytona Charger that recently underwent a PC repair due to an error on the ASP Switch that shorted out because of magnetic waves supposedly from the Alternator. Strangely enough it fried the pc's ability to turn on the heated O2 sensors. After much much much money later the pc is now fixed and of course returned to super stock abilities. I need to update the pcm and I cannot do that because the tuner will not allow me to put it into that section that allows the pcm update. I need to see if the pc will take the same tuner that I have used for it due to the pc fix. I cannot see if it needs to be remarried though due to the pcm needing an update that I cannot put on the user tuner itself to update. Either I just don't remember how to use the files or put them on the tuner but I do know that I need help. If someone from diablo can help me by a pm I greatly appreciate it. I spent about an hour this am trying to contact someone via phone but I just got the wonderful music and message about the tuners that wasn't helpful at all. I greatly appreciate your time. -Dustin.
have you run the updater on a pc to see if the update downloads?
If not post the info.xml file from the intune drive here and we'll check it out.
Posted: Wed Jan 04, 2017 4:51 pm
by Mburnsy
I have a 2011 dodge charger 5.7L hemi and it was brought to the dealership as well and they flashed the system and does anyone else have a file to fix i can fix this with asap.
Posted: Wed Jan 04, 2017 4:57 pm
by Entrusted
I have run the updater and it put only two files on the tuner none of which was this calibration update.
Posted: Thu Jan 05, 2017 9:41 am
the files are downloading for me, please try again.
The device is not yet up to date hence it hasnt been updated.
Posted: Thu Jan 05, 2017 2:17 pm
by Entrusted
then I suppose the diablo updater does not work properly considering I've tried to download at least 5 times now. I will try to do it again. Also when I look into the file tunes there are none. Update: checked updater again says all files are up to date. Another update: I was finally able to download the other files one by one manually. Will see if it let's me plug into my car pc. Final update: Car PC accepted the calibration update, tune working as designed. Thank you for the support, not sure why the downloader doesn't see that it has other files that need to be downloaded then doesn't download them.
