PUCK STACKED WITH PREDITOR ON EXTREME
JRUSH188
Post by JRUSH188 »
WILL THIS HURT MY ENGINE. I AM AFRAID IT IS OVER TIMING IT. DOES THE PUCK AND THE PREDITOR INCREASE TIMING. :?:
johan
RE: PUCK STACKED WITH PREDITOR ON EXTREME
Post by johan »
No it will not hurt your motor, the predator adds timing, the puck does not.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Dodgezilla
Post by Dodgezilla »
It's the trans you will need to worry about.......
You do need to watch your boost because you can overspool the stock turbo with that setup and you may get an overboost code if you do....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
johan
Post by johan »
^^what he said.
Took the 07 truck up to 120mph last night, and key counts are not zeroed out anymore. :)
Hopefully i will have something up today.
Diablosport INC
MegaBOMB
Post by MegaBOMB »
Hey Johan,
It's great that your addressing the "detectable" factor of the predator by not zeroing key counts. However, are you also looking at other key parameters such as fuel used.
My 2006 also suffers from a very rough idle, as I've mentioned here in the past, but I don't have my CALID as I quit using my Predator long ago as the erratic idle can't be good for my truck. The truck feels like it needs new spark plugs, if it had any to replace, when I have the Predator installed.
Thanks!
fyrguy316
Re: RE: PUCK STACKED WITH PREDITOR ON EXTREME
Post by fyrguy316 »
johan wrote:^^what he said.
johan,
are you fixing the key count issue on all predators? i have the 7130 and would like that issue resolved for mine as well. thanks.
05 2500 SLT, 600 cummins, 6 SPD, Predator/Puck Stack, Quad. Boost Fooler, ISSPRO Pyro and Boost, ISSPRO Turbo Temp Monitor, MBRP Exhaust, AFE Stg 2 PG 7, REESE rail setup for 5th wheel or The Goose, PJ Gooseneck 25 ft 14,000 GVW
johan
Post by johan »
MegaBOMB wrote:Hey Johan,
Thanks!
I will check that out too while we are at it.
It appears that everyone with idle issues have 06's, i am going to try to get one of those in here as well.
Diablosport INC
johan
Post by johan »
johan,
Yes once i get done with the u7131 i have some duramax stuff to finish up then i was going to do the 7130.
Diablosport INC
JRUSH188
RE: Re: RE: PUCK STACKED WITH PREDITOR ON EXTREME
Post by JRUSH188 »
THE TRANS WON'T BE A PROBLEM, I ALREADY HAVE INSTALLED THE ATS FULL BILLIT TRANS WITH FIVE STAR CONVERTER. IF THE PUCK DOES NOT ADD TIMING THEN WHAT DOES IT DO JUST ADD FUEL PRESSURE AND DURATIION. IF THAT IS THE CASE I DON'T HAVE TO RUN THE STACKER TUNES IF I DON'T WANT TO AND I CAN STILL RUN THE PUCK, OR AM I MISSING SOMETHING.
03 2500 SO, ATS BILLIT 48RE, BANKS HIGH RAM AFE STAGE 2 5 INCH EXHAUST W/ NO MUFFLER FASS 150/150 PYRO BOOST FUEL PRESS OIL PRESSURE AND WATER TEMP AUTO METER GAUGES PREDITOR AND PUCK DDP 90 HORSE INJECTORS STAGE 3 WATER METH INJECTION
johan
Post by johan »
You will most likely get a low rail pressure code if you run the puck with a non-stack tune.
Diablosport INC
fyrguy316
Post by fyrguy316 »
johan wrote:
johan,
ok, thanks. i'll be watching for it.
Dodgezilla
The Puck is pressure only. Not even boost fooling. The Predator does not boost fool either BTW.
Lots of guys are running the Non-stack tunes (which add pressure) and the Puck for a little more pressure.
fyrguy316
Re: RE: Re: RE: PUCK STACKED WITH PREDITOR ON EXTREME
Post by fyrguy316 »
Dodgezilla wrote:The Puck is pressure only. Not even boost fooling. The Predator does not boost fool either BTW.
from what i was told by the techs and by other people that have the stack the puck was timing and duration. the tow and performance tunes were timing and duration, but the extreme was timing, duration and added pressure. this is what i was told when i bought mine a year or so ago.
Dodgezilla
I think someone told you wrong. It is pressure only. Now the Predator on the other hand, they won't tell us exactly how it makes the power but I think it's a combo of all three. I was actually going to reluctantly sell mine but if Johan has fixed the keycount issue I may keep it. The power is just plain awesome.....
fyrguy316
Post by fyrguy316 »
Dodgezilla wrote:I think someone told you wrong. It is pressure only. Now the Predator on the other hand, they won't tell us exactly how it makes the power but I think it's a combo of all three. I was actually going to reluctantly sell mine but if Johan has fixed the keycount issue I may keep it. The power is just plain awesome.....
i have to agree with you there, the power is awesome. the key counts don't bother me too much cuz my dealer knows i have it in there. its the fact that it was advertised as undetectable and it is definately detectable. i'll be able to tell in the upcoming months what does what. i'll have my fuel pressure gauges in for lift and rail pressure so i'll be able to tell which does pressure and which does timimg.
