u7140
u7140
i just got the c&l racer kit with tuner u7140 the tuner has on tune in for the kit now my 06 gt stang runs like.....well not good i have tryed down loading
the dsdownloader to in stall a diferent tune and it crashes can some one help or im just out $500.00 bills
Re: u7140
Can we get some more informations about his predator revision?chopper wrote:i just got the c&l racer kit with tuner u7140 the tuner has on tune in for the kit now my 06 gt stang runs like.....well not good i have tryed down loading
This predator has OEM SELECT. Go to Options/ Troubleshooting/ OEM Select. You will have multiple OEM accounts to select from. C&L, Steeda, ect. Please choose C&L logo and then go back to the main menu. Go through Performance Menu and select the C&L Racer tune.chopper wrote:it has tunes for stock air cleaner
the serial# d000c16
part# u7140 stang-05
verison v.8r36
born 02/14/2007 [830]
dose this help?
chopper
Cole
Cole[/quote]
that info should be added to the book that comes with the tuner
chopper
Cole[/quote]
chopper
I have a Volant CAI (with chip that splices into the MAF harness). GT 05 Manual
Is there a way I can tune the car and set the MAF straight without using the chip that came with the Volant CAI? and without having to take it to a professional tuner? They said I would need to take it in so they can tune it properly for the setup I'm running. I'd like the ease of use with the normal tunes from the tuner.
I will also have new shorty heads and Cat-back mid muffler setup from Pypes shortly.
Thanks, Dave
Thanks, Dave
- Vas@Diablosport
- Vas@Diablosport
Well, generally, the aftermarket CAI/maf senor housing is 5-10% larger in diameter than the factory piping. So by putting the factory MAF sensor into the larger piping, there is 5-10% more air going in to the motor that is not being accounted for. So by adding that additional 5% to the maf curve, you are telling the computer that the vehicle is receiving 5% more air than what the maf is reading at all times.
No, i don't work here.
