u7146 and Halo spark plug?
Talerno
Post by Talerno »
Hi,
I'm not sure if you know anything about these spark plugs I'm getting ready to put into my '04 Mach1. The Halo spark plugs from LSGBrisk are supposed to increase mileage and power and reduce emissions. http://www.lsgbrisk.com They say that the plugs ignite the air/fuel more quickly then a conventional plug, saying it ignites it 30% faster then a conventional plug. If this is the case, and I am using the performance tune in the predator, will the timing be ok, or would that need to be adjusted? Yes they recommend disconnecting the battery while installing so that the computer will relearn it's settings more quickly. I included the link to their site so you can see what I'm talking about.
Any ideas?
Thanks,
Mike
dynometer
RE: u7146 and Halo spark plug?
Post by dynometer »
i think i would save my money and put it in the gas tank rather than invest in snake oil...
Talerno
Re: RE: u7146 and Halo spark plug?
Post by Talerno »
dynometer wrote:i think i would save my money and put it in the gas tank rather than invest in snake oil...
Well, I'll see what happens. I have them installed already. Now I'm just giving the ecm some time to readjust itself and I'll see what I get. I have been reading something which seem to indicate that there is a difference with these plugs. If I don't like them I'll put my old plugs back in and get a refund.
I'll let you know what I find. I believe I should still be good with the predator settings for the mach1.
Talerno
RE: Re: RE: u7146 and Halo spark plug?
Post by Talerno »
Well, after the first tank of gas I'm just over 1 mpg better then I was (even when new). So, so far so good. After a couple tanks I'll put another update in here.
Return to “Predator Ford Gas”
