U7140 06 Mustang GT
Posted: Tue Jul 19, 2016 5:42 pm
by FrankBlack
I have an 06 GT that came with the Diablo Predator U7140. The tune for 93 octane already installed. I have a couple of questions.
1) Do I need a CAI now that the tune has been installed? Currently there is a K&N high flow filter installed in place of the paper one.
2) With out a CAI does the car run rich?
3) Currently thinking about installing a Ford Racing CAI. It requires a tune.
https://fordracingpartsbydonwood.com/el ... 9603-m463/
The DL page has no updates for that CAI. Does the update from this page cover that?
https://forum.diablosport.com/viewtopic.php?f=9&t=59633
4) Does this update cover any CAI I might want to install? Or do I need a custom tune?
5) Does the update from here
https://forum.diablosport.com/viewtopic.php?f=9&t=59633 (same as mentioned above) have updated parameters for my car?
Thank you,
Frank
Re: U7140 06 Mustang GT
Posted: Wed Jul 20, 2016 9:03 am
by DiabloMatt
FrankBlack wrote:I have an 06 GT that came with the Diablo Predator U7140. The tune for 93 octane already installed. I have a couple of questions.
the fileter helps but a GOOD cai is the best (i recomend the JLT over all)
if you are using the base 93 tune and are not using a CAI then you will not be running rish or lean. if you add a cai withouht a tune you will be VERY lean
we are no longer updating the predators but the CAI tunes should already be on yours. if not i can make you one.
we cover 95% of the CAI on the market
depends on what revision you are on now. what does it say when you boot up the tool at the top?
Thank you,
Frank
Posted: Wed Jul 20, 2016 11:52 am
by FrankBlack
Hi Matt,
Thanks for the quick response and info.
When I boot up the Predator it says: Predator V. 9r03
Thank you,
Frank
Posted: Wed Jul 20, 2016 1:22 pm
by DiabloMatt
FrankBlack wrote:Hi Matt,
Thank you,
Frank
if you return the tool to stock and run the updater program (assuming you have the cable) it will update itself to 9R09
Posted: Wed Jul 20, 2016 2:39 pm
by FrankBlack
Hi Matt,
So this is what I need to do.
1) Flash my vehicle back to "stock"
2) Update the Predator with the file from here
3) Re-flash my vehicle with whatever tune I need.
Correct?
Thank you again,
Frank
Posted: Wed Jul 20, 2016 3:47 pm
by DiabloMatt
that is correct...
Posted: Wed Jul 20, 2016 3:51 pm
by FrankBlack
Awesome, thank you again!!!!
