2005 silverado cant change gear ratio
2005silverado
Post by 2005silverado »
i have a 2005 silverado 1500 z71 and i just put 4.10 gears in and just got my diablo tuner. and i cant adjust the gear ratio can someone help me?
Re: 2005 silverado cant change gear ratio
post the files from the tunes folder and tel us what the stock gears were as well.
2005silverado
the stock gears are 3.42 and the aftermarket gears are 4.10
save this to the i2 drive and let the device import it then you may load the cusotm tune to the truck and speedo will be correct.
2005silverado
Thank you
2005silverado
Is that only work on the 91 tune that I sent you?
