Modify/Restore Parameters ?
Posted: Tue Aug 09, 2016 1:22 pm
by JTWalker
If I modify my Throttle response (Trinity) by say +7% and install the tune it's not much change. So I modify the throttle response again with +12%. Now do I have + 12% or + 19% ?
If I want to go back to 0% do I just modify parameters again by -12/-19% or use "Restore Parameters"
Does "Restore Parameters" restore only the ones I've changed (I hope)?
Can I modify parameters and save that "new tune" with a different file name from the original so I have both available?
Re: Modify/Restore Parameters ?
Posted: Wed Aug 10, 2016 6:03 pm
by JTWalker
I guess nobody from Diablo Sport reads here. Can anybody answer my questions.
Posted: Thu Aug 11, 2016 8:17 am
if you load the tune with 10%, then go back and add another 10%, it adds up.
Use the reset param option to set them back to stock or simply set them back to default 0.
You can grab a copy of the last tune written, rename it and save it back to the tool as a custom tune.
Posted: Thu Aug 11, 2016 8:42 am
by JTWalker
Thank you. If you read this again, one more question. The throttle response only goes up to 20% but since you say it's accumulative, will 10 + 15 actually go to 25% ?
Thanks again for the help.
Posted: Thu Aug 11, 2016 9:15 am
by 06MonteSS
no..
if you change it to 10%.. and then you go back in to change it some more, it will show that it is already at 10%.. so if you then adjust it to 15%, then the total will be 15%, not 25...
Posted: Thu Aug 11, 2016 9:26 am
by JTWalker
Thanks for your reply but your response seems to disagree with Mike. You both can't be right.
Posted: Thu Aug 11, 2016 9:40 am
by JTWalker
I just tried it and you are right that it shows that I was already at 10% so it would make sense that moving it up to 15% would just mean it's now at 15% and 20% is the real limit.
Posted: Thu Aug 11, 2016 9:41 am
by 06MonteSS
yes that is correct.. I had no doubts that
I was right...
Posted: Thu Aug 11, 2016 10:16 am
sorry, I thought you were referring to reloading the tune and adding throttle boost again as a custom, my bad.
Posted: Thu Aug 11, 2016 10:19 am
also, with Trinity, reloading the last tune written as a custom tune wont work, I was thinking i2 when I said that.
If you want to do that post the LTW here and I can make it a full file for you.
Posted: Sun Aug 28, 2016 7:24 pm
by Boosted11100
I just removed 20% of the fuel under WOT, and the AF only leaned out half of a point?
Is that normal? I still need to go another half point leaner but the Trinity is maxed out at 20%
