Problem updating my i-1000-DCX
rajansingh241994
Post by rajansingh241994 »
I tried updating my I-1000-DCX because with the latest update to my PCM the old tune I had for my 2013 dodge charger rt daytona no longer is compatible. When updating the tuner I get the following message on my tuner: "The current firmware revision (1r03x) cannot be replaced by the firmware package within group_update_0." After I press continue on my tuner it says "failed to update.itfg". Some help would be greatly appreciated! Thanks in advance.
Re: Problem updating my i-1000-DCX
load this to the intune drive and let it import it then you can run the updater from there.
intune-1r03y.itf
(1.82 MiB) Downloaded 301 times
rajansingh241994
Ok thanks! After doing this will my tuner be ready to be plugged into my car to load the tune back onto my charger or will I have to redownload the tune?
Return to “General Questions”
