which tune you recommend? New Tuner
dtoulet
Post by dtoulet »
Hi i just bought my I2 Tuner and i would like to know what tune do you recommend to get the best MPG.
i have a 2010 5.3L silverado pickup and i always use 92 octane gas. which tune do you recommend between the diablo tune or the MPG booster.
I´ve read some treads saying they use the 87 tune for daily driving, but i don´t know which one should i use.
what are the differences between the 3 pre loaded tunes? i have had a hard time finding info describing the differences.
AllUSA
Re: which tune you recommend? New Tuner
Post by AllUSA »
I would test them each out. See what you like and don't like if so on each tune. Then send the tunes to a custom tuner like myself. And have a custom tune built.
http://www.doctortuned.com
DYNO TUNING.
Custom Tuning GM, Dodge, Fords
843-246-5832
If you use good 92 octane gas, then install the Diablo Tune.. you will have better power/performance with the Diablo Tune and 92 octane gas, since the timing is set higher for the higher octane.
The 87 octane tune and mpg booster tune are for 87/89 octane and just use stock timing settings...
For a custom tune to get the most out of your GM vehicle, hit up http://www.diablewtune.com
