Snow Stage II Meth for N/A or CAI to fix LTFT
Posted: Mon Aug 29, 2016 7:39 pm
Trinity Users:
I have a stock 2014 Corvette Z51 7 speed. Just started using Trinity to explore a noticeable rough idle. The idle is rough for both stock and Diablo 91 tune.
I see STFT varying at idle (+/- 20 rpm) as well O2 sensor voltages. My LTFT is around -9% on both banks.
I was thinking it was questionable 91 real gas causing the problem. In process of cycling through various gas stations and running logs.
Some other ideas to consider:
1) LTFT is low because I run Ecomode to/from lake. Maybe that has trained my LTFT to back off because of only 4 cylinders?
2) LTFT is low because the factory tune runs a little rich and the ECM is backing off?
3) LTFT is low because the engine is starved for air and a CAI or Meth injection may address that?
The ECM shows AFR is 14.7/1 across all loads.
Any suggestions or experience with this would be appreciated.
Vargas1
Vargas1
