Potentially fried cpu with the t1000
Post your Cummins related Trinity questions here.
Reppusmic
Post by Reppusmic »
I have a 13 dodge charger with a Trinity t1000 the other day the tuner only had 2 red lights lit and as I drove to get to work my car started severely misfiring...has anyone else have this problem? I can't get any scan tool to connect to my vehicle now
Re: Potentially fried cpu with the t1000
if the tool had a problem and locked up it should not have any effect on the car, does it run properly now?
Reppusmic
Post by Reppusmic »
No the car is misfiring over 3g rpm under that it is fine. It only started when the tuner locked up
try a battery reset, disconnect it and drain voltage then reconnect.
Reppusmic
Post by Reppusmic »
I did that, cleared the code but there still stored in the computer. I was able to get my personal can tool to link to the car the codes It's throwing are U0002 and p0304
P0304 is a legit misfire code, seems perhaps there was something that happened to the car that needs to be addressed.
Return to “Trinity Dodge Diesel”
