Hi
Loaded an i2 onto a 2016 silverado 5.3 and after the tune it says "ice possible, drive with caution" at startup and registers the outside temp as 32 degrees. Even after return it to stock with the backup, same thing. Any ideas?
2016 silverado "ice possible" after tune
Dodge & GM Tuner
Re: 2016 silverado "ice possible" after tune
yes, normal, since the modules get reset during a tune flash.. it straightens itself out after a few drive cycles.. no issue...
Was just wondering how you are liking the intune on ur 2016 Silverado I was looking to pick one up I'm just trying to see what you thought about it was it worth it?
An absolute yes! My 2016 Silverado had 59 miles on it when I pulled into a mall parking lot right outside of the dealership and installed it. Its easy to install and there are already a couple of pre installed Diablo tunes on it based the octane fuel you prefer to use. I have tried 3 pre installed tunes and they are great. I did the 22 MPG tune for a trip to Ft Bragg from PA. My milage was 24 average and thats with DOD shut off.
Its an easy unit to use also. I had this tuner for my 2014 Silverado also.
