BEST TUNE TO USE!!!
golfer221
BEST TUNE TO USE!!!
Post by golfer221 »
Have a 2001 Chevy Silverado and wanted to know what tune is the best overall. Also would like to know some parameter changes that has been done by a member that I could try for more across the board power
White Denali
Re: BEST TUNE TO USE!!!
Post by White Denali »
A lew tune,,lol he takes the guess work out of it.
settings that are good for one person, may not be for you.. every vehicle is different... even if they're the same and have similar mods... location/weather, fuel used, elevation/altitude, etc etc all play a role...
you'd need to do some data logging to see how your specific vehicle is running, what needs to be adjusted, and by how much, etc...
if you use 87/89 octane gas, then use the 87 octane tune.
if you use 91/93 octane gas, then use the Diablo/Performance Tune..
if you want a custom tune done, you can check out www.diablewtune.com
Return to “Trinity GM Gas”
