InTune I1000 Registration Issue
frogfaced
Post by frogfaced »
Hi there,
I recently picked up a used InTune. The prior owner reset his vehicle and it appears to be unmarried. When I first plugged it in to update, it appeared to install the updates just fine. However, my vehicle is claiming it needs a PCM Calibration update and when I plugged back into the computer, the unit told me it needed to be registered to update.
It should already be registered to the prior owner, correct? I am attaching the info file if that helps at all.
Thanks in advance for the help!
info.xml
(1.91 KiB) Downloaded 310 times
frogfaced
frogfaced
Post by frogfaced »
Have any mods had a chance to review this? Am I posting in the right place?
Thanks again to anybody that can help.
Re: InTune I1000 Registration Issue
please run the updater again now, it will download the file for you.
frogfaced
frogfaced
Post by frogfaced »
Thanks, Mike. That did get the PCM calibration loaded. I still got the "Cannot update until this device is registered" error. Does not seem to be an issue, since it looks like it's on the most recent update, but should I be concerned about that going forward?
Thanks!
Re: frogfaced
frogfaced wrote:Thanks, Mike. That did get the PCM calibration loaded. I still got the "Cannot update until this device is registered" error. Does not seem to be an issue, since it looks like it's on the most recent update, but should I be concerned about that going forward?
Thanks!
save this to the intune drive to register it.
_registration.itf
(387 Bytes) Downloaded 336 times
frogfaced
frogfaced
Post by frogfaced »
Thanks for all your help, Mike. Everything is working great!
