All right, I'm at a loss.
I figured I could fix this with google and the forums, but I've ran out of steam.
Just purchased a new 2011 Chrysler 300C, great car so far, and my second 300.
My InTune unit is unmarried. I am attempting to write a tune. It does its communication dance with the PCM, then in short, states there "could be a PCM Calibration Update" for my vehicle. I have selected "YES", when I unplug as it instructed and plug it into my PC, launch the updater... my unit tells me that it already has the newest data available.
When I select "NO" (Red X) at the PCM Calibration Update Prompt, it tells me that the Vehicle is Not Supported, Contact DiabloSport.
Not really sure what else to do at this point. I have family and friends that also use DiabloSport, your units have always been easy to use and plug and play as long as you updated.
Thanks in advanced for any and all assistance!!
- NCTAR
(info file attached)
2011 Chrys 300C (5.7l) - Vehicle Not Supported
Re: 2011 Chrys 300C (5.7l) - Vehicle Not Supported
save this to the i2 drive, let the device import it then go to the truck and select tune vehicle and load it then you may load the tunes.
Done.
When I moved it it said:
"Calibration Update <my Vin>_68065112ac is Already Loaded" - Continue
I'll give it another attempt at the OBD later, but it sounds like the unit already had this.
Wish me luck!
-NC
Wish me luck!
-NC
It worked!
Thanks for your help.
