Page 1 of 2
PCM Calibration Needed
Posted: Wed Sep 21, 2016 8:03 pm
by rtgordon
I traded in my Challenger... returned to stock and unmarried the unit. I tried to install it on a 2012 Ram... It said I needed pcm update. I went through all of the process to get it installed to i2 software and updated everything. I put it back on the Ram and it said PCM updated... I thought maybe I missed something so I put it back on the computer. It said it was all up to date. I put it back on the Ram and it said it needed pcm update. Any ideas what's going on here?
Thanks!
Gordon
Re: PCM Calibration Needed
Posted: Fri Sep 23, 2016 8:20 am
please post he info.xml file from the i2 drive.
Posted: Sun Sep 25, 2016 10:30 am
by rtgordon
Thanks Mike!
I'm not sure why the dates on everything in the INTUNE directory say 12/31/2010 if I'm supposedly updating files when I run the updater. I attached a few screen caps along with the info.xml file. I appreciate the assistance.
Posted: Mon Sep 26, 2016 10:17 am
its working fine, it downloaded the file for me.
save this to the i2 drive, let the too limport t then go to the vehicle and load the update then you can load the tunes.
Posted: Tue Sep 27, 2016 2:32 am
by outrid3r
Hi Mikel
I've been following a few threads about calibration needed, I'm running into the same issue. 2014 Dodge Ram. I'm using a Mac, I've downloaded the latest firmware and followed the steps but I keep on getting the same message.
Here's what I have so far
Also, when I try to drag and drop the tune for 2011-2014 Dodge/Chrysler/Jeep, it says my tuner is not compatible with that tune
https://forum.diablosport.com//download ... p?id=13161
Thanks a lot!!
Posted: Tue Sep 27, 2016 11:57 am
please attach the info.xml file from the intune drive.
Posted: Tue Sep 27, 2016 9:20 pm
by outrid3r
Right, sorry, i posted it wrong. Here's the info xml
Thanks again!
info.xml
info.xml
Posted: Wed Sep 28, 2016 12:01 pm
outrid3r wrote:Right, sorry, i posted it wrong. Here's the info xml
Thanks again!
info.xml
info.xml
you have a standard i-1000 there, it will not work on the 2013 model you are trying to tune, that requires the older i-1000-dcx or current i2010.
Posted: Wed Sep 28, 2016 12:39 pm
by outrid3r
Thanks for getting back to me
Posted: Tue Oct 11, 2016 2:16 pm
by 1yota91
i have a 2013 dodge ram 5.7 i had to bring it in because the trans wasn't shifting so i look the tune off and they did a PCM update and now so says it calibration needed i tired to update it but theirs no updates for it
Posted: Wed Oct 12, 2016 10:23 am
1yota91 wrote:i have a 2013 dodge ram 5.7 i had to bring it in because the trans wasn't shifting so i look the tune off and they did a PCM update and now so says it calibration needed i tired to update it but theirs no updates for it
post the info.xml file from the intune drive please.
Posted: Wed Oct 12, 2016 12:37 pm
by 1yota91
<?xml version="1.0"?>
-<tool_info>
<main svn="9115" sw_rev="1r04j" full_version="InTune-1r04j 03/14/2016 10:51:37 AM"/>
<registration status="0" sn="J2BT881-4"/>
<cal_id PCM="68089639AM"/>
<restore bc="6" vin="3C6JR6AT2DG501633" id="0"/>
<system_db vin="1r01g" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01v" mfr="DCX"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="3C6JR6AT2DG501633" oem="DCX" calid="68089639AM"/>
<updates count="4"/>
<oem tool_oem="DIABLODCX"/>
<reg reg="52aeF0hynt/OwlB2B70ymnlfZJz/jSYjfepLmIFIroRepCrs3+rzCqokxcfSVfmRzEqSGITK6K7s00TdD/MP+h4fJK/CO4gDPAupZmLZfKxE1C2N0vzmmnvRiyNt3qgnAUKLr/P7ZWdayNE+1J4vWhy+7W73wSu05yNCiOrRannoF/rXag9CrVeckHbW7+460sw52a422cbYJDSl/7Nov7Mz1UwE2bGIzKv+5ukUpChU/pONwpXryCbxI6uMziT0Qgons3P4hYJGADqn+j0wOqCr4ElIv99iW0TbN8LuVDFMpqOEkJfL57HoBztmYqJg4eh5CLL01o1YC713qN/j+XLhHWOw/SzUcOnJBgQn9NhWwL3AlIJ6najAxk2Iy6RsrG2D699Z7hiHmfAWqZRhEl2KLa1GkPR3XjU9ojc55cs1zfq/ldWG3epcsVU8keqUDqi3VrkoHz9SYKVvgOmMQRJ0MgzAaB0/dVFwZmurZXKfuSX2NqqlqZ4fzKn1acbAJXzr6hCdHGFOJOqcvdY8CJr42Rb25aJbzK0Vtbm/jORBg5xUaKU0uAUzwDpi5ExzF6wDGREB3dlUp6HPthpGK5qe7T6+Y08Ft1MZ6FWm/J6JbNEHrNOnGjjsHMWVVBwIAiIEIlObEBtKlhLVTPzGLthzR/4v8pAltb+W39/GGEUogMpb77ltzMiMPVHqqlMShqPElst6OYYCuUpvMlED1Ula7XeEs7S/Ha9JHDIP149HnyqU1N/GWAoGyplTm/klIFMHLqlQT9JF6rGitF2p4wcaIEZkjvPs3ntcq0TPlk/oUVBVtBE3mua2gxFNXiNo/Oc95isXue2bqkAwTaeDyQKULgiiEjJ49OHFTpiTZHvuf5dm8Dq8WVZIHMXGbuS/F4VfBTR5W9V7tH4sml+b8GrCRebGrgm7znLOTyc2KWoTn8K+rXnM0tj9oK6C9T8x3nrb8CPJJshlX1tOV0UMSRU1J/vTwsyLqs4g4iSdeOr09eMZL2n88GOh2L0pJm6FzuTHO//iCrihH+YTRY9RVonlrnvJnmVxwxCXTY4jPHBckz76e50WWosFzMKCG3Wf+ZEli0v/Jx1W902LGZ7ydNDzm/zF48wqh1v37fJusliBZNbSnXw6iDoHrLWfvc0IzTno242GcpCmTw4oXGTNhBdvY0Z0S221Vxj9joTSaJBtT/3cCNUH/sHEx3Pgi5mlnHr3ec6wOQsJMU0BetaDq7ZJ9VU6rPB5McpDG5nSdGeK7Jybd/sP2LEdoC+wOK8QbkCn1ee4mk3qMA=="/>
</tool_info>
Posted: Wed Oct 12, 2016 12:41 pm
by 1yota91
sorry i posted it wrong lol
info.xml
Posted: Wed Oct 12, 2016 1:13 pm
by JimH
1yota91 wrote:sorry i posted it wrong lol
info.xml
Try running the updater now.
Posted: Wed Oct 12, 2016 1:31 pm
by 1yota91
it updated and now is being installed on my truck. thank you very much
