Predator has disabled my PATS system. I have written numerous posts and called you on this starting back in December before Christmas and have had no response. WTF? My entire system of theft components was replaced. The fix was a new PCM. Ford said a program had been burned into it and they couldnt communicate to it. The oil pump also went haywire and was replaced. This was after I had installed the R19DZ upgrade to the tool.
Where is my support team?
After the new PCM was installed by Ford I reinstalled the Predator and the same damn flashing/disabling of the PATS system is happening again!
P.A.T.S
Excursionist
P.A.T.S
02 Excursion 7.3 liter
Monster Exhaust w/Power Elbow
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Updated U7170 v-9r03
Edge Juice w/Attitude
Cal ID TNAA7Y5
Transmission Transducer, Solenoid and Springs
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
RE: P.A.T.S
With the tune installed can you check the calid in the truck and let me know what it says for the calid.
Cole Stevens
Excursionist
RE: P.A.T.S
The Cal ID is listed in my Info above TNAA7Y5. I can check it again if necessary
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
